Saltar al contenido principal
FAO Schwarz Apex 1 Remote Control Battery Replacement
Qué necesitas
  1. FAO Schwarz Apex 1 Remote Control Battery Replacement, Remote Control Battery: paso 1, imagen 1 de 1
    • Remove the plastic battery cover to get at the battery compartment.
    • The cover can be removed by pressing down on the lever and sliding.
  2. FAO Schwarz Apex 1 Remote Control Battery Replacement: paso 2, imagen 1 de 3 FAO Schwarz Apex 1 Remote Control Battery Replacement: paso 2, imagen 2 de 3 FAO Schwarz Apex 1 Remote Control Battery Replacement: paso 2, imagen 3 de 3
    • Remove the dead battery, being careful not to damage the internal battery connectors.
    • The battery is a bit wedged in there, so you'll have to press hard to pop it out.
  3. FAO Schwarz Apex 1 Remote Control Battery Replacement: paso 3, imagen 1 de 3 FAO Schwarz Apex 1 Remote Control Battery Replacement: paso 3, imagen 2 de 3 FAO Schwarz Apex 1 Remote Control Battery Replacement: paso 3, imagen 3 de 3
    • Insert the new 6F22 9 volt battery.
    • Line up the positive icons on the battery with the positive icons in the battery compartment.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 7
Todo El Tiempo: 475
