Saltar al contenido principal
FAO Schwarz Apex 1 Front Axle Replacement
Qué necesitas
  1. FAO Schwarz Apex 1 Front Axle Replacement, Wheel: paso 1, imagen 1 de 3 FAO Schwarz Apex 1 Front Axle Replacement, Wheel: paso 1, imagen 2 de 3 FAO Schwarz Apex 1 Front Axle Replacement, Wheel: paso 1, imagen 3 de 3
    • Position device so that the wheels are on a firm surface .
    • Using a J1 Screwdriver bit, remove the 11 mm screw from the center of the wheel.
  2. FAO Schwarz Apex 1 Front Axle Replacement: paso 2, imagen 1 de 1
    • After removing the 11 mm screw, firmly grip the wheel and pull away from the vehicle.
  3. FAO Schwarz Apex 1 Front Axle Replacement, Front Wheel Springs: paso 3, imagen 1 de 2 FAO Schwarz Apex 1 Front Axle Replacement, Front Wheel Springs: paso 3, imagen 2 de 2
    • Position device upside down so that the screws on the plastic axle pieces can be removed.
    • Use J1 screwdriver bit to remove two 10 mm screws to remove the plastic axle pieces to make access to the telescopic piston easier.
  4. FAO Schwarz Apex 1 Front Axle Replacement: paso 4, imagen 1 de 1
    • Secure a firm grip on the spring and telescopic piston.
    • Pull telescopic piston holding the spring off the device (this may be difficult).
  5. FAO Schwarz Apex 1 Front Axle Replacement: paso 5, imagen 1 de 1
    • Using a tool such as a spudger, gradually maneuver spring off of telescopic piston.
  6. FAO Schwarz Apex 1 Front Axle Replacement, Front Axle: paso 6, imagen 1 de 3 FAO Schwarz Apex 1 Front Axle Replacement, Front Axle: paso 6, imagen 2 de 3 FAO Schwarz Apex 1 Front Axle Replacement, Front Axle: paso 6, imagen 3 de 3
    • Carefully turn the vehicle over so that the bottom side is facing upward.
    • Using a J1 Screwdriver bit, remove the two 10 mm screws that secure the wheel bearing.
    • Pull the plastic piece that secures the wheel bearing off of the axle.
  7. FAO Schwarz Apex 1 Front Axle Replacement: paso 7, imagen 1 de 2 FAO Schwarz Apex 1 Front Axle Replacement: paso 7, imagen 2 de 2
    • Position the axle entirely upright before lifting away from the vehicle.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 5
Todo El Tiempo: 254
