Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Ezonics EZ-307 Main Board and USB Cable Replacement
Qué necesitas
  1. Ezonics EZ-307 Main Board and USB Cable  Replacement, Get Tools: paso 1, imagen 1 de 1
    • A Phillips Head Size Zero Screw Driver
    Pregunta a FixBot
    Agregar Comentario
  2. Ezonics EZ-307 Main Board and USB Cable  Replacement, Detach the Base: paso 2, imagen 1 de 1
    • Using a Phillips-head screwdriver, remove each of the 3 screws from the underside of the camera head.
    Pregunta a FixBot
    Agregar Comentario
  3. Ezonics EZ-307 Main Board and USB Cable  Replacement, Set Aside the Base: paso 3, imagen 1 de 1
    • Gently pull back the base and set it aside.
    • Be careful not to pull out the USB cable attachment when taking off the base
    Pregunta a FixBot
    Agregar Comentario
  4. Ezonics EZ-307 Main Board and USB Cable  Replacement, Remove USB Connector: paso 4, imagen 1 de 3 Ezonics EZ-307 Main Board and USB Cable  Replacement, Remove USB Connector: paso 4, imagen 2 de 3 Ezonics EZ-307 Main Board and USB Cable  Replacement, Remove USB Connector: paso 4, imagen 3 de 3
    • Gently remove the white connector with the red, green, white & black cord with your fingers. This connector is the end of the USB cable.
    Pregunta a FixBot
    Agregar Comentario
  5. Ezonics EZ-307 Main Board and USB Cable  Replacement, Remove Top Lens Casing: paso 5, imagen 1 de 3 Ezonics EZ-307 Main Board and USB Cable  Replacement, Remove Top Lens Casing: paso 5, imagen 2 de 3 Ezonics EZ-307 Main Board and USB Cable  Replacement, Remove Top Lens Casing: paso 5, imagen 3 de 3
    • Press tab on inside of device to release silver ring.
    • Gently remove top (silver) ring of lens casing with your fingers.
    Pregunta a FixBot
    Agregar Comentario
  6. Ezonics EZ-307 Main Board and USB Cable  Replacement, Remove Inner Lens Casing: paso 6, imagen 1 de 2 Ezonics EZ-307 Main Board and USB Cable  Replacement, Remove Inner Lens Casing: paso 6, imagen 2 de 2
    • Gently remove inner casing of the lens (silver with a black ring).
    • Be careful not to break the small notch at the top, which holds the inner casing in place.
    Pregunta a FixBot
    Agregar Comentario
  7. Ezonics EZ-307 Main Board and USB Cable  Replacement, Remove the Inner Ring: paso 7, imagen 1 de 2 Ezonics EZ-307 Main Board and USB Cable  Replacement, Remove the Inner Ring: paso 7, imagen 2 de 2
    • Remove the small, black, ridged inner ring around the lens with your fingers.
    Pregunta a FixBot
    Agregar Comentario
  8. Ezonics EZ-307 Main Board and USB Cable  Replacement, Unscrew the Lens: paso 8, imagen 1 de 2 Ezonics EZ-307 Main Board and USB Cable  Replacement, Unscrew the Lens: paso 8, imagen 2 de 2
    • Unscrew the lens counterclockwise with your fingers.
    Pregunta a FixBot
    Agregar Comentario
  9. Ezonics EZ-307 Main Board and USB Cable  Replacement, Carefully Remove Board From Outer Casing: paso 9, imagen 1 de 2 Ezonics EZ-307 Main Board and USB Cable  Replacement, Carefully Remove Board From Outer Casing: paso 9, imagen 2 de 2
    • Turn the hollow outer casing so that you can see inside of it.
    • Gently pull out main board with fingers.
    Pregunta a FixBot
    Agregar Comentario
  10. Ezonics EZ-307 Main Board and USB Cable  Replacement, A New Board: paso 10, imagen 1 de 2 Ezonics EZ-307 Main Board and USB Cable  Replacement, A New Board: paso 10, imagen 2 de 2
    • Insert your new board into the outer casing. Be sure that it rests firmly between the sets of rails on either side.
    Pregunta a FixBot
    Agregar Comentario
  11. Ezonics EZ-307 Main Board and USB Cable  Replacement, Reassembly of Lens: paso 11, imagen 1 de 2 Ezonics EZ-307 Main Board and USB Cable  Replacement, Reassembly of Lens: paso 11, imagen 2 de 2
    • Twist the lens piece in clockwise and then insert black ring around the lens.
    Pregunta a FixBot
    Agregar Comentario
  12. Ezonics EZ-307 Main Board and USB Cable  Replacement, Reassemble the Lens: paso 12, imagen 1 de 3 Ezonics EZ-307 Main Board and USB Cable  Replacement, Reassemble the Lens: paso 12, imagen 2 de 3 Ezonics EZ-307 Main Board and USB Cable  Replacement, Reassemble the Lens: paso 12, imagen 3 de 3
    • Line up notch on inner lens casing (silver with black ring) with notch on body of camera. Gently push it into place, being sure not to break the notch.
    • Insert the silver ring. You should hear it click into place.
    Pregunta a FixBot
    Agregar Comentario
  13. Ezonics EZ-307 Main Board and USB Cable  Replacement, Insert the USB Cord: paso 13, imagen 1 de 3 Ezonics EZ-307 Main Board and USB Cable  Replacement, Insert the USB Cord: paso 13, imagen 2 de 3 Ezonics EZ-307 Main Board and USB Cable  Replacement, Insert the USB Cord: paso 13, imagen 3 de 3
    • Hold the camera in one hand with the hollow side facing up.
    • Hold the USB cable in your other hand with the four small holes facing up.
    • Plug the USB cable into the port.
    Pregunta a FixBot
    Agregar Comentario
  14. Ezonics EZ-307 Main Board and USB Cable  Replacement, Reassemble the Base of the Camera: paso 14, imagen 1 de 1
    • Lay the USB cord in the notch at the base of the camera bottom.
    • Place the bottom back onto the camera top.
    Pregunta a FixBot
    Agregar Comentario
  15. Ezonics EZ-307 Main Board and USB Cable  Replacement, Reassemble the Base of the Camera: paso 15, imagen 1 de 1
    • Line up the base of the camera with the screw holes.
    • Use a Phillips-head screwdriver to twist the three screws back into place.
    Pregunta a FixBot
    Agregar Comentario
Conclusión
Lyndsi
Miembro Desde 10/13/14
7 Reputación
1 Guía escrita
Equipo
Ohio State, Team 1-5, Mccook Fall 2014 Miembro de Ohio State, Team 1-5, Mccook Fall 2014
OSU-MCCOOK-F14S1G5
Miembros de 4
2 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 13
Ultimos 30 días: 61
Todo El Tiempo: 1,486
