Saltar al contenido principal
ExoPC Slate Battery Replacement
Qué necesitas
  1. ExoPC Slate Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Turn the PC on its back with the screen facing down and pull on the piece of plastic shown in the image. Use your fingernails to prod into the depression where the two plastic covers meet.
  2. ExoPC Slate Battery Replacement: paso 2, imagen 1 de 2 ExoPC Slate Battery Replacement: paso 2, imagen 2 de 2
    • Using the 00 Phillips screwdriver remove the two screws in the corners.
    • Using your left hand pull at the exposed section of the PC while simultaneously pushing the right with the thumb of your other hand. This will release the plastic clips allowing back cover to slide off, as shown from the picture
    • When removing the back cover make sure that the ribbon connectors going to the screen are not damaged. Carefully fold over the cover like a book.
  3. ExoPC Slate Battery Replacement: paso 3, imagen 1 de 3 ExoPC Slate Battery Replacement: paso 3, imagen 2 de 3 ExoPC Slate Battery Replacement: paso 3, imagen 3 de 3
    • Remove the tape covering the metal shield as shown in the image.
    • Remove the 12 screws using the Phillips #00 screwdriver.
    • Dislodge the shield by pulling the prongs away from underneath the battery. The shield should come completely off.
  4. ExoPC Slate Battery Replacement: paso 4, imagen 1 de 1
    • Remove tape from the side of the battery.
    • Disconnect the battery from the motherboard.
    • Gently remove the battery.
Conclusión
Aaron Moore
Miembro Desde 10/30/18
217 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 11
Todo El Tiempo: 460
