Saltar al contenido principal
Euro Cuisine WM520 Heart Shaped Waffle Maker Disassembly
Qué necesitas
  1. Euro Cuisine WM520 Heart Shaped Waffle Maker Disassembly, Euro Cuisine WM520 Heart Shaped Waffle Maker Disassembly: paso 1, imagen 1 de 1
    • Remove the two 10 mm screws from the plastic wire covering using a T5 Torx screwdriver.
    • Remove the covering.
  2. Euro Cuisine WM520 Heart Shaped Waffle Maker Disassembly: paso 2, imagen 1 de 1
    • Remove the two 11 mm screws from the white plastic holding the outlet cord in place using a Phillips screwdriver.
  3. Euro Cuisine WM520 Heart Shaped Waffle Maker Disassembly: paso 3, imagen 1 de 1
    • Remove the three 20 mm screws from the base of the iron using a Phillips screwdriver.
    • Two screws are beneath the rubber feet and one is in the wire compartment.
  4. Euro Cuisine WM520 Heart Shaped Waffle Maker Disassembly: paso 4, imagen 1 de 1
    • Remove the base of the waffle maker to expose the heating conductor and wires.
Conclusión
Una persona más ha completado esta guía.
Documentos Adjuntos
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 2
Ultimos 30 días: 4
Todo El Tiempo: 62
