Saltar al contenido principal
Eureka SuctionSeal 2.0 Pet Filters Replacement
  1. Eureka SuctionSeal 2.0 Pet Filters Replacement, Dust Cup: paso 1, imagen 1 de 2 Eureka SuctionSeal 2.0 Pet Filters Replacement, Dust Cup: paso 1, imagen 2 de 2
    • Place the device upright with the brush roller closest to you.
    • Pull up on the latch at the top of the dust cup.
    • Tilt the top of the dust cup forward and pull towards yourself, removing the container from the device.
  2. Eureka SuctionSeal 2.0 Pet Filters Replacement, Filters: paso 2, imagen 1 de 2 Eureka SuctionSeal 2.0 Pet Filters Replacement, Filters: paso 2, imagen 2 de 2
    • Locate the gray exhaust filter cover at the top of the vacuum's base.
    • Grip the two tabs in the middle of the filter cover and rotate it counter-clockwise.
    • Lift the cover away from the vacuum.
  3. Eureka SuctionSeal 2.0 Pet Filters Replacement: paso 3, imagen 1 de 1
    • Grab the tab on the exhaust filter.
    • Lift the filter straight up from the vacuum's base.
  4. Eureka SuctionSeal 2.0 Pet Filters Replacement: paso 4, imagen 1 de 2 Eureka SuctionSeal 2.0 Pet Filters Replacement: paso 4, imagen 2 de 2
    • Locate the lid at the top of the previously removed dust cup.
    • Lift the latch and lay the cover back.
  5. Eureka SuctionSeal 2.0 Pet Filters Replacement: paso 5, imagen 1 de 2 Eureka SuctionSeal 2.0 Pet Filters Replacement: paso 5, imagen 2 de 2
    • Pull up on the tag and remove the filter.
Conclusión
Anna Snyder
Miembro Desde 10/02/17
336 Reputación
3 Guías creadas
Equipo
Cal Poly, Team S4-G5, Livingston Fall 2017 Miembro de Cal Poly, Team S4-G5, Livingston Fall 2017
CPSU-LIVINGSTON-F17S4G5
3 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 7
Todo El Tiempo: 584
