Saltar al contenido principal
Eureka EasyClean 71C Motor Replacement
Qué necesitas
  1. Eureka EasyClean 71C Motor Replacement, Bottom Cover: paso 1, imagen 1 de 1
    • Unscrew the two 18.1 mm PH2 Phillips head screws on the bottom of the vacuum.
  2. Eureka EasyClean 71C Motor Replacement: paso 2, imagen 1 de 1
    • Pry off the Riser Visor using the plastic opening tool.
  3. Eureka EasyClean 71C Motor Replacement: paso 3, imagen 1 de 1
    • Remove the screw cap using the metal spudger.
    • First-time removal of the screw cap can be difficult. The screw cap isn’t vital, so don’t worry about damaging the screw cap and just keep trying until it comes out.
  4. Eureka EasyClean 71C Motor Replacement: paso 4, imagen 1 de 2 Eureka EasyClean 71C Motor Replacement: paso 4, imagen 2 de 2
    • Unscrew the 14mm PH2 Phillips head screw.
    • Pull the bottom cover off of the rest of the casing.
  5. Eureka EasyClean 71C Motor Replacement, Casing: paso 5, imagen 1 de 1
    • Pull the power switch all the way up and remove the dust cup.
  6. Eureka EasyClean 71C Motor Replacement: paso 6, imagen 1 de 2 Eureka EasyClean 71C Motor Replacement: paso 6, imagen 2 de 2
    • Unscrew the six 18.1mm PH2 Phillips head screws on the side of the vacuum.
    • Pull the casing apart.
  7. Eureka EasyClean 71C Motor Replacement, Motor: paso 7, imagen 1 de 1
    • Pull out the switch board.
    • Ensure the vacuum is turned off and unplugged before handling any of the electronics.
  8. Eureka EasyClean 71C Motor Replacement: paso 8, imagen 1 de 2 Eureka EasyClean 71C Motor Replacement: paso 8, imagen 2 de 2
    • Desolder the pictured red and black wires.
    • For instructions on how to solder and desolder wires, visit this guide.
Conclusión
Tanner Durnil
Miembro Desde 11/06/17
631 Reputación
6 Guías creadas
Equipo
IUPUI, Team S6-G4, Baechle Fall 2017 Miembro de IUPUI, Team S6-G4, Baechle Fall 2017
IUPUI-BAECHLE-F17S6G4
3 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 6
Todo El Tiempo: 726
