Saltar al contenido principal
Introducción
If you determine that your vacuum is no longer picking up debris, this guide will help you to replace the washable filters to increase the suction.
  1. Press the grey dust cup release button and gently pull the dust cup towards you. Press the grey dust cup release button and gently pull the dust cup towards you.
    • Press the grey dust cup release button and gently pull the dust cup towards you.
  2. Lift the latch on the top of the dust cup cover to open. You can now see the foam filter inside the cyclone portion of the dust cup. Lift the latch on the top of the dust cup cover to open. You can now see the foam filter inside the cyclone portion of the dust cup.
    • Lift the latch on the top of the dust cup cover to open. You can now see the foam filter inside the cyclone portion of the dust cup.
  3. Kits de Reparación de Android
    Estás a un kit de tu nueva pantalla o batería.
    Comprar Ahora
    Comprar Ahora
  4. Remove the white filter by lifting the gray foam filter handle.
    • Remove the white filter by lifting the gray foam filter handle.
  5. Push the white mesh, segment below the filter handle downward so it pops out of the grey filter holder. This will remove the filter.
    • Push the white mesh, segment below the filter handle downward so it pops out of the grey filter holder. This will remove the filter.
  6. If filter is unable to be washed, place a new filter in gray holder.
    • If filter is unable to be washed, place a new filter in gray holder.
Conclusión
Celina Burchett
Miembro Desde 13/10/14
1,101 Reputación
8 Guías creadas
Equipo
Clemson, Team 2-2, Benson Fall 2014 Miembro de Clemson, Team 2-2, Benson Fall 2014
CLEM-BENSON-F14S2G2
4 Miembros
8 Guías creadas
Agregar Comentario
Ver Estadísticas:
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 27
Todo El Tiempo: 3,589
