Saltar al contenido principal
Eureka AirSpeed Bagless Zuum Vacuum Accessory Holder Replacement
Qué necesitas
  1. Eureka AirSpeed Bagless Zuum Vacuum Accessory Holder Replacement, Hose: paso 1, imagen 1 de 2 Eureka AirSpeed Bagless Zuum Vacuum Accessory Holder Replacement, Hose: paso 1, imagen 2 de 2
    • On the back of the vacuum, pull the handle connected to the hose away from the vacuum.
  2. Eureka AirSpeed Bagless Zuum Vacuum Accessory Holder Replacement: paso 2, imagen 1 de 2 Eureka AirSpeed Bagless Zuum Vacuum Accessory Holder Replacement: paso 2, imagen 2 de 2
    • Grasp the thick smooth collar at the bottom of the hose and twist left (counterclockwise) to remove the hose.
  3. Eureka AirSpeed Bagless Zuum Vacuum Accessory Holder Replacement, Accessory Holder: paso 3, imagen 1 de 1
    • Using a T15 Torx Security Screwdriver, remove the screw on each side of the indention in which the hose normally rests.
  4. Eureka AirSpeed Bagless Zuum Vacuum Accessory Holder Replacement: paso 4, imagen 1 de 1
    • Upon removal of the two screws, the accessory holder can be removed from the vacuum body.
Conclusión
Una persona más ha completado esta guía.
Celina Burchett
Miembro Desde 10/13/14
1,122 Reputación
8 Guías creadas
Equipo
Clemson, Team 2-2, Benson Fall 2014 Miembro de Clemson, Team 2-2, Benson Fall 2014
CLEM-BENSON-F14S2G2
4 Miembros
18 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 635
