Saltar al contenido principal
Eureka AirSpeed Bagless Zuum Brush Roll Replacement
Qué necesitas
  1. Eureka AirSpeed Bagless Zuum Brush Roll Replacement, Brush Roll: paso 1, imagen 1 de 2 Eureka AirSpeed Bagless Zuum Brush Roll Replacement, Brush Roll: paso 1, imagen 2 de 2
    • Step on the grey release button located between the two back wheels to lower the handle flat to the floor.
    • Insure the vacuum is unplugged before starting the process of removing the brush roll.
  2. Eureka AirSpeed Bagless Zuum Brush Roll Replacement: paso 2, imagen 1 de 1
    • Using a Phillips #2 screwdriver, remove the four screws from each corner of the brush roll cover.
  3. Eureka AirSpeed Bagless Zuum Brush Roll Replacement: paso 3, imagen 1 de 2 Eureka AirSpeed Bagless Zuum Brush Roll Replacement: paso 3, imagen 2 de 2
    • Remove the brush cover from the vacuum base, by pulling straight up.
  4. Eureka AirSpeed Bagless Zuum Brush Roll Replacement: paso 4, imagen 1 de 1
    • Firmly press upwards from below the brush roll on the side opposite the belt.
  5. Eureka AirSpeed Bagless Zuum Brush Roll Replacement: paso 5, imagen 1 de 1
    • After one end is displaced, remove the other side by pressing firmly upwards from below the the brush roll.
  6. Eureka AirSpeed Bagless Zuum Brush Roll Replacement: paso 6, imagen 1 de 1
    • Once the brush roll is displaced from the base, detach the belt from the brush roll in order to clean the brush roll.
Conclusión
6 personas más completaron esta guía.
Celina Burchett
Miembro Desde 10/13/14
1,122 Reputación
8 Guías creadas
Equipo
Clemson, Team 2-2, Benson Fall 2014 Miembro de Clemson, Team 2-2, Benson Fall 2014
CLEM-BENSON-F14S2G2
4 Miembros
18 Guías creadas
Un comentario
Brush roll replacement is a no brainer. It is the brush roll assembly that turns the brush that I need to fix. Cannot determine what tool to use as it doesn't come off using a regular screwdriver and eureka won't tell me what to ese.
Tami Jones - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 31
Todo El Tiempo: 12,047
