Introducción
Replace the small wheel or 'roller' on the bottom of the Eureka.
Qué necesitas
Press the black separator switch and lightly pull the bottom half away from the top.
Turn the vacuum head's bottom over so that the inside of the head is facing up.
Using a Phillips #00 screwdriver, press down on metal bar of the roller on one side until it releases from the housing.
Turn the vacuum head's bottom over and pull at the roller and bar until they are completely out of the housing.
Casi Terminas!
Linea de Meta
