Saltar al contenido principal
Eureka 1660SP Roller Replacement
Qué necesitas
  1. Eureka 1660SP Roller Replacement, Roller: paso 1, imagen 1 de 2 Eureka 1660SP Roller Replacement, Roller: paso 1, imagen 2 de 2
    • Press the black separator switch and lightly pull the bottom half away from the top.
  2. Eureka 1660SP Roller Replacement: paso 2, imagen 1 de 2 Eureka 1660SP Roller Replacement: paso 2, imagen 2 de 2
    • Remove the vacuum head from the lower half of the body.
  3. Eureka 1660SP Roller Replacement: paso 3, imagen 1 de 3 Eureka 1660SP Roller Replacement: paso 3, imagen 2 de 3 Eureka 1660SP Roller Replacement: paso 3, imagen 3 de 3
    • Turn the vacuum head wheels up and remove all seven 13.9mm screws from the bottom using a #2 Phillips head screwdriver.
    • Separate the top and bottom of the vacuum head. Set the top aside.
  4. Eureka 1660SP Roller Replacement: paso 4, imagen 1 de 2 Eureka 1660SP Roller Replacement: paso 4, imagen 2 de 2
    • Turn the vacuum head's bottom over so that the inside of the head is facing up.
    • Using a Phillips #00 screwdriver, press down on metal bar of the roller on one side until it releases from the housing.
    • Turn the vacuum head's bottom over and pull at the roller and bar until they are completely out of the housing.
  5. Eureka 1660SP Roller Replacement: paso 5, imagen 1 de 1
    • Press the new bar and roller into place.
    • Replace the screws.
Linea de Meta
Equipo
UMass Dartmouth, Team 1-1, Gulbrandsen Fall 2013 Miembro de UMass Dartmouth, Team 1-1, Gulbrandsen Fall 2013
UMASSD-GULBRANDSEN-F13S1G1
3 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 11
Todo El Tiempo: 444
