Saltar al contenido principal
Eureka 1660SP Extendable Pole Realignment
Qué necesitas
  1. Eureka 1660SP Extendable Pole Realignment, Motor Housing: paso 1, imagen 1 de 2 Eureka 1660SP Extendable Pole Realignment, Motor Housing: paso 1, imagen 2 de 2
    • Before you start, make sure your vacuum is unplugged the power outlet.
    • Press and hold down the black button below the handle while pulling the pole out.
  2. Eureka 1660SP Extendable Pole Realignment: paso 2, imagen 1 de 2 Eureka 1660SP Extendable Pole Realignment: paso 2, imagen 2 de 2
    • Press the black separator switch to separate the top and bottom halves of the vacuum.
  3. Eureka 1660SP Extendable Pole Realignment: paso 3, imagen 1 de 3 Eureka 1660SP Extendable Pole Realignment: paso 3, imagen 2 de 3 Eureka 1660SP Extendable Pole Realignment: paso 3, imagen 3 de 3
    • Use a #2 Phillips head screwdriver to remove six 13.9mm screws from the side of the motor housing (top half) as shown.
    • Remove two 14.1mm screws from the front face of the housing. You are now all set to open the housing.
    • Keep a watchful eye on the two screws from the front face. These two have additional collars to their necks and will not fit in any of the other holes, yet no other screw will fit in their spots without the collar.
  4. Eureka 1660SP Extendable Pole Realignment, Realignment of the extendable pole: paso 4, imagen 1 de 1
    • Once the housing is open, locate the solid chrome plated piece at the front end of the extendable pole.
  5. Eureka 1660SP Extendable Pole Realignment: paso 5, imagen 1 de 2 Eureka 1660SP Extendable Pole Realignment: paso 5, imagen 2 de 2
    • On the side of the motor housing which does not hold the engine, find the center track which runs along the inside of the housing.
    • Re-insert the chrome plated piece into the center track.
Conclusión
Una persona más ha completado esta guía.
Evan Fodi
Miembro Desde 09/24/13
122 Reputación
2 Guías creadas
Equipo
UMass Dartmouth, Team 1-1, Gulbrandsen Fall 2013 Miembro de UMass Dartmouth, Team 1-1, Gulbrandsen Fall 2013
UMASSD-GULBRANDSEN-F13S1G1
3 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 447
