Saltar al contenido principal
Eufy RoboVac 11S Filters Replacement
Qué necesitas
  1. Eufy RoboVac 11S Filters Replacement, Filters: paso 1, imagen 1 de 2 Eufy RoboVac 11S Filters Replacement, Filters: paso 1, imagen 2 de 2
    • Press the dust collector release button.
    • Pull the dust collector out.
  2. Eufy RoboVac 11S Filters Replacement: paso 2, imagen 1 de 2 Eufy RoboVac 11S Filters Replacement: paso 2, imagen 2 de 2
    • Push the blue button up and open the dust collector.
    • Empty the dust collector, and throw all the dust into the trash bin.
  3. Eufy RoboVac 11S Filters Replacement: paso 3, imagen 1 de 3 Eufy RoboVac 11S Filters Replacement: paso 3, imagen 2 de 3 Eufy RoboVac 11S Filters Replacement: paso 3, imagen 3 de 3
    • Pull the hooks up to take out the pre-filter.
    • Pull the filter lightly because the hook by the filter is easy to break.
  4. Eufy RoboVac 11S Filters Replacement: paso 4, imagen 1 de 3 Eufy RoboVac 11S Filters Replacement: paso 4, imagen 2 de 3 Eufy RoboVac 11S Filters Replacement: paso 4, imagen 3 de 3
    • Take out the high-performance filter to the side and use a cleaning brush to clean the filter.
    • Take out the foam filter to the side and dispose of it in the trash bin.
  5. Eufy RoboVac 11S Filters Replacement: paso 5, imagen 1 de 1
    • Use the cleaning brush to sweep the dust from the pre-filter.
  6. Eufy RoboVac 11S Filters Replacement: paso 6, imagen 1 de 2 Eufy RoboVac 11S Filters Replacement: paso 6, imagen 2 de 2
    • Put the pre-filter back in the dust collector.
    • Use your finger to push the top button first.
    • Push the filter lightly because the hook by the filter is easy to break.
  7. Eufy RoboVac 11S Filters Replacement: paso 7, imagen 1 de 2 Eufy RoboVac 11S Filters Replacement: paso 7, imagen 2 de 2
    • Open the back of the dust collector.
    • Replace the white foam filter.
    • Put the black high-performance filter at the top of the foam filter.
    • Make sure to put the foam filter before the high-performance filter, otherwise the robot will have problems cleaning.
Conclusión
2 personas más completaron esta guía.
felix
Miembro Desde 05/13/20
181 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 12
Ultimos 30 días: 86
Todo El Tiempo: 4,822
