Saltar al contenido principal
Eton FRX3 Rechargeable Battery Pack Replacement
  1. Eton FRX3 Rechargeable Battery Pack Replacement, Rechargeable Battery Pack: paso 1, imagen 1 de 1
    • Pull the plastic tab on the battery compartment cover panel to loosen it, then pull the panel off.
  2. Eton FRX3 Rechargeable Battery Pack Replacement: paso 2, imagen 1 de 1
    • Disconnect the battery pack wires from the device and remove the battery pack.
Conclusión
To reassemble your device, follow these instructions in the reverse order.
3 personas más completaron esta guía.
Kenneth Sills
Miembro Desde 02/10/16
762 Reputación
6 Guías creadas
Equipo
USF Tampa, Team 1-6, Nance Spring 2016 Miembro de USF Tampa, Team 1-6, Nance Spring 2016
USFT-NANCE-S16S1G6
Miembros de 4
13 Guías creadas
4 comentarios
My question is where can you find an FRX3 replacement battery?
jalwitt - Contestar
Hey mate, you can buy the battery packs from a number of sources. Here's the link to one of those sources https://www.amazon.com/HQRP-FR200-BAT-3A...
james -
is it ok to replace it with a higher capacity lithium battery?
troydeleon - Contestar
As long as the specifications match, that should be fine. Just be careful when swapping out components in circuits, as it can potentially destroy the device if they're incompatible!
Kenneth Sills -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 14
Ultimos 30 días: 31
Todo El Tiempo: 5,721
