Introducción
The small, plastic switch just under the screen and just above the hand crank is quite fragile. You may find that it becomes damaged and needs to be replaced. Luckily, it's not too difficult to do!
Qué necesitas
Pull the plastic tab on the battery compartment cover panel to loosen it, then pull the panel off.
On the bottom of the device case's face are two T10 screws. Use a T10 Torx screwdriver to remove the two screws.
Unplug the socket connection from the motherboard as shown in the image.
Remove the six Phillips #0, 1 cm screws that secure the motherboard to the case.
On the back of the motherboard, just below the LCD screen, gently pull up on the small, black plastic switch to remove it.
