Saltar al contenido principal
Ethernet Port Replacement
Qué necesitas
  1. Ethernet Port Replacement, Linksys EA6900 Disassembly: paso 1, imagen 1 de 3 Ethernet Port Replacement, Linksys EA6900 Disassembly: paso 1, imagen 2 de 3 Ethernet Port Replacement, Linksys EA6900 Disassembly: paso 1, imagen 3 de 3
    • Remove the antennas by unscrewing them from the base.
    • Flip over the device and locate the four rubber feet on the bottom.
    • Remove the rubber feet with tweezers
  2. Ethernet Port Replacement: paso 2, imagen 1 de 1
    • Remove the 0.4cm head screws from each slot with the #1 Phillips head Screwdriver.
  3. Ethernet Port Replacement: paso 3, imagen 1 de 1
    • Use a blue plastic opening tool to remove the top cover.
    • Move the blue plastic opening tool gently underneath the top cover from side to side.
  4. Ethernet Port Replacement: paso 4, imagen 1 de 3 Ethernet Port Replacement: paso 4, imagen 2 de 3 Ethernet Port Replacement: paso 4, imagen 3 de 3
    • Gently lift the motherboard and remove it from the case
    • Put the motherboard over a (preferably white) surface.
  5. Ethernet Port Replacement, Ethernet Ports: paso 5, imagen 1 de 3 Ethernet Port Replacement, Ethernet Ports: paso 5, imagen 2 de 3 Ethernet Port Replacement, Ethernet Ports: paso 5, imagen 3 de 3
    • Locate the Ethernet ports
    • Flip the motherboard and locate the 40 solder points corresponding to the Ethernet ports
    • Melt the 40 solder points using a soldering gun.
    • Wait between five and seven minutes for the ports to cool down.
  6. Ethernet Port Replacement: paso 6, imagen 1 de 1
    • Hold the motherboard down and use the spudger to remove the Ethernet Ports.
Conclusión
6 personas más completaron esta guía.
Denis
Miembro Desde 09/15/16
584 Reputación
3 Guías creadas
Equipo
USF Tampa, Team 11-1, Blackwell Fall 2016 Miembro de USF Tampa, Team 11-1, Blackwell Fall 2016
USFT-BLACKWELL-F16S11G1
4 Miembros
12 Guías creadas
Un comentario
Can you make a guide to replace the antenna base connector, mine get broken at the base, I wonder if it is possible to make the cable connection directly to the antenna, does that could work?
Enrique Jendrix - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 15
Ultimos 30 días: 85
Todo El Tiempo: 7,035
