Qué necesitas
The ethernet diagnostics port is located behind the drivers side instrument panel cover.
The plastic panel is secured by 3 metal flex trim clips. Using an appropriate pry tool pry backwards at the points indicated
After opening the side panel, hold onto the cover until you disconnect the key fob antenna connector. Failure to do so could cause excessive strain on the wiring
Reach into the opening to feel for the diagnostic cable, if you have never had the car serivced it may be tucked down into the recess
There should only be one cable with a circular white connector
Connect the FakraHSD to Ethernet cable until you hear a click.
To disconnect press down on the small finger and gently pull the connectors apart.
