Saltar al contenido principal
Ethernet Diagnostics Port
Qué necesitas
    • The ethernet diagnostics port is located behind the drivers side instrument panel cover.
    • The plastic panel is secured by 3 metal flex trim clips. Using an appropriate pry tool pry backwards at the points indicated
    • After opening the side panel, hold onto the cover until you disconnect the key fob antenna connector. Failure to do so could cause excessive strain on the wiring
    • Reach into the opening to feel for the diagnostic cable, if you have never had the car serivced it may be tucked down into the recess
    • There should only be one cable with a circular white connector
    • Pull out the connector, but be careful, since there is not much slack in the cable. This is part of a large and expensive wiring harness.
    • Connect the FakraHSD to Ethernet cable until you hear a click.
    • To disconnect press down on the small finger and gently pull the connectors apart.
Conclusión
obrien28
Miembro Desde 06/02/13
553 Reputación
2 Guías creadas
Equipo
iMaster Repairs Miembro de iMaster Repairs
Business
1 Miembro
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 705
