Introducción
Are the buttons on your Escort Radar 9500IX's cracked or jammed? If this is the case, then follow this guide to replace the buttons on your radar.
Partes
No se requieren partes.
  1. Remove the three 1.2 mm Phillips #1 screws on the back of the device.
    • Remove the three 1.2 mm Phillips #1 screws on the back of the device.
  2. Pry off the back panel of the radar using the nylon spudger.
    • Pry off the back panel of the radar using the nylon spudger.
  3. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  4. Carefully pry the grey frame off the black plastic covering using the nylon spudger. Carefully pry the grey frame off the black plastic covering using the nylon spudger. Carefully pry the grey frame off the black plastic covering using the nylon spudger.
    • Carefully pry the grey frame off the black plastic covering using the nylon spudger.
  5. Slowly peel the buttons off the button board. Slowly peel the buttons off the button board.
    • Slowly peel the buttons off the button board.
Conclusión
Kennedy Morales
Miembro Desde 20/10/17
626 Reputación
6 Guías creadas
Equipo
Ver Estadísticas:
Ultimas 24 Horas: 2
Últimos 7 Días: 2
Últimos 30 Días: 8
Todo El Tiempo: 109
