Saltar al contenido principal
Equity Alarm Clock 13014 Clock Bell Hammer Replacement
Qué necesitas
  1. Equity Alarm Clock 13014 Clock Bell Hammer Replacement, Back Cover of Clock: paso 1, imagen 1 de 3 Equity Alarm Clock 13014 Clock Bell Hammer Replacement, Back Cover of Clock: paso 1, imagen 2 de 3 Equity Alarm Clock 13014 Clock Bell Hammer Replacement, Back Cover of Clock: paso 1, imagen 3 de 3
    • Using a Phillip's Screwdriver, remove the three screws on the back cover of the clock.
  2. Equity Alarm Clock 13014 Clock Bell Hammer Replacement, Back Cover of Clock (2): paso 2, imagen 1 de 1
    • Using your hands, remove the back cover of the clock by grasping it and pulling it upwards.
  3. Equity Alarm Clock 13014 Clock Bell Hammer Replacement, Cellinoid Cover: paso 3, imagen 1 de 2 Equity Alarm Clock 13014 Clock Bell Hammer Replacement, Cellinoid Cover: paso 3, imagen 2 de 2
    • Using a Phillips Screwdriver, remove the Cellinoid Cover from inner clock apparatus.
  4. Equity Alarm Clock 13014 Clock Bell Hammer Replacement, Bell Hammer: paso 4, imagen 1 de 2 Equity Alarm Clock 13014 Clock Bell Hammer Replacement, Bell Hammer: paso 4, imagen 2 de 2
    • Using your fingers, remove the bell hammer from the inner apparatus of clock.
  5. Equity Alarm Clock 13014 Clock Bell Hammer Replacement, You are Finished: paso 5, imagen 1 de 1
    • Remove the clock's bell hammers and you are finished. Be sure to replace the old bell hammers with new ones.
    • Starting from Step 5, repeat each previous step to reassemble the clock.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 10
Ultimos 30 días: 33
Todo El Tiempo: 3,014
