Saltar al contenido principal
Equity Alarm Clock 13014 Alarm Switch Replacement
Qué necesitas
  1. Equity Alarm Clock 13014 Alarm Switch Replacement, Replacing the alarm switch: paso 1, imagen 1 de 3 Equity Alarm Clock 13014 Alarm Switch Replacement, Replacing the alarm switch: paso 1, imagen 2 de 3 Equity Alarm Clock 13014 Alarm Switch Replacement, Replacing the alarm switch: paso 1, imagen 3 de 3
    • Remove the battery door using your finger nail or an opening tool.
  2. Equity Alarm Clock 13014 Alarm Switch Replacement, Remove screws: paso 2, imagen 1 de 2 Equity Alarm Clock 13014 Alarm Switch Replacement, Remove screws: paso 2, imagen 2 de 2
    • Use a Phillips #1 screwdriver to remove the 3 screws on the back cover.
  3. Equity Alarm Clock 13014 Alarm Switch Replacement, Remove Cover: paso 3, imagen 1 de 1
    • Remove the back cover gently.
    • DO NOT pull the back cover off quickly or you may damage the wires connected.
  4. Equity Alarm Clock 13014 Alarm Switch Replacement: paso 4, imagen 1 de 2 Equity Alarm Clock 13014 Alarm Switch Replacement: paso 4, imagen 2 de 2
    • Use a Phillips #1 screwdriver to remove the small screw located above the alarm switch.
    • Remove the small screw located below the alarm switch as well.
  5. Equity Alarm Clock 13014 Alarm Switch Replacement: paso 5, imagen 1 de 2 Equity Alarm Clock 13014 Alarm Switch Replacement: paso 5, imagen 2 de 2
    • Place the end of the soldering iron on the end of the wire connected to the copper cylinder to detach the wire.
    • If you are unfamiliar with soldering, take a look at this article: How to Solder and Desolder Connections.
    • To replace the alarm switch, attach one end of new alarm switch wire to the copper cylinder.
    • Use a Phillips #1 screwdriver to reinstall the switch screws.
    • Follow steps in reverse order to assemble the clock.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 16
Todo El Tiempo: 982
