Saltar al contenido principal
Epson VS250 Speaker Replacement
Qué necesitas
  1. Epson VS250 Speaker Replacement, Shell: paso 1, imagen 1 de 1
    • Place the projector on a flat surface.
    • Orient the projector so that the the word "Epson" is facing you.
    • Using the Phillips #1 screwdriver, to loosen the screw on the top right corner of the projector. The screw only needs to be loosened.
  2. Epson VS250 Speaker Replacement: paso 2, imagen 1 de 1
    • Slide the cover to the right and lift the cover up and out to remove.
  3. Epson VS250 Speaker Replacement: paso 3, imagen 1 de 1
    • Using a Phillips #1 screwdriver, remove the three 6 mm screws that hold the side portion of the projector in place.
    • Use the same Phillips #1 screwdriver to remove the single 10 mm screw that is holding the side cover of the projector in place.
  4. Epson VS250 Speaker Replacement: paso 4, imagen 1 de 1
    • Use a Phillips #1 screwdriver to remove the two 10 mm screws that are holding the side cover of the projector in place.
  5. Epson VS250 Speaker Replacement: paso 5, imagen 1 de 2 Epson VS250 Speaker Replacement: paso 5, imagen 2 de 2
    • Flip the projector so that it lays upside down.
    • Using a Phillips #1 screwdriver, remove the eight 10 mm screws that secure the side portion of the projector.
  6. Epson VS250 Speaker Replacement: paso 6, imagen 1 de 1
    • Remove the front cover from the projector by pulling it off of the device.
  7. Epson VS250 Speaker Replacement: paso 7, imagen 1 de 1
    • Use a Phillips #1 screwdriver to remove the two 10 mm screws.
    • After completing this step you will be able to remove the back cover from the projector.
  8. Epson VS250 Speaker Replacement: paso 8, imagen 1 de 1
    • Slowly lift up the top shell up and out of the device.
    • Disconnect the ribbon cable from the motherboard and remove the shell from the device.
  9. Epson VS250 Speaker Replacement, Speaker: paso 9, imagen 1 de 1
    • Use a Phillips #1 screwdriver to remove the two 10 mm screws holding the speaker in place.
  10. Epson VS250 Speaker Replacement: paso 10, imagen 1 de 2 Epson VS250 Speaker Replacement: paso 10, imagen 2 de 2
    • Pinch and unplug the speaker cable from the motherboard.
    • Remove the speaker from the device.
Conclusión
Warren Cutlip
Miembro Desde 09/28/21
604 Reputación
5 Guías creadas
Equipo
Clemson, Team 4-2, Hunter Fall 2021 Miembro de Clemson, Team 4-2, Hunter Fall 2021
CLEM-HUNTER-F21S4G2
5 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 2
Ultimos 30 días: 7
Todo El Tiempo: 136
