Saltar al contenido principal
Epson Stylus Photo 1400 Housing Replacement
Qué necesitas
  1. Epson Stylus Photo 1400 Housing Replacement, Housing: paso 1, imagen 1 de 1
    • Turn off the printer.
    • Disconnect all data connections coming into the printer such as USB, networkd cables, firewire, etc. as well as removing the power cord.
  2. Epson Stylus Photo 1400 Housing Replacement: paso 2, imagen 1 de 2 Epson Stylus Photo 1400 Housing Replacement: paso 2, imagen 2 de 2
    • Locate the IEEE cover in the back.
    • Gently slide the cover to the right to unlatch, then pull to remove it.
  3. Epson Stylus Photo 1400 Housing Replacement: paso 3, imagen 1 de 2 Epson Stylus Photo 1400 Housing Replacement: paso 3, imagen 2 de 2
    • Using a Phillips #2 screwdriver, remove the four 10 mm screws shown.
    • Remove the 6 mm screw that holds the rear housing in place.
  4. Epson Stylus Photo 1400 Housing Replacement: paso 4, imagen 1 de 2 Epson Stylus Photo 1400 Housing Replacement: paso 4, imagen 2 de 2
    • Remove the rear housing by pulling it backwards.
  5. Epson Stylus Photo 1400 Housing Replacement: paso 5, imagen 1 de 3 Epson Stylus Photo 1400 Housing Replacement: paso 5, imagen 2 de 3 Epson Stylus Photo 1400 Housing Replacement: paso 5, imagen 3 de 3
    • Insert a plastic opening tool into the cutouts of the lower housing.
    • Release the two tabs of the side housing by lifting the tool in an upward motion.
    • Remove the side housing by pulling it outwards.
  6. Epson Stylus Photo 1400 Housing Replacement: paso 6, imagen 1 de 2 Epson Stylus Photo 1400 Housing Replacement: paso 6, imagen 2 de 2
    • Both side housings are attached by the same type of mechanism.
    • Using the same method, remove the other side housing.
  7. Epson Stylus Photo 1400 Housing Replacement: paso 7, imagen 1 de 3 Epson Stylus Photo 1400 Housing Replacement: paso 7, imagen 2 de 3 Epson Stylus Photo 1400 Housing Replacement: paso 7, imagen 3 de 3
    • Lift the paper support.
    • Open the printer cover and front cover.
  8. Epson Stylus Photo 1400 Housing Replacement: paso 8, imagen 1 de 3 Epson Stylus Photo 1400 Housing Replacement: paso 8, imagen 2 de 3 Epson Stylus Photo 1400 Housing Replacement: paso 8, imagen 3 de 3
    • Remove the four 10 mm Phillips #2 screws from the sides of the printer.
    • Remove the three 6 mm Phillips #2 screws.
  9. Epson Stylus Photo 1400 Housing Replacement: paso 9, imagen 1 de 2 Epson Stylus Photo 1400 Housing Replacement: paso 9, imagen 2 de 2
    • Detach the tabs from the pins on each side by pulling it outwards.
  10. Epson Stylus Photo 1400 Housing Replacement: paso 10, imagen 1 de 2 Epson Stylus Photo 1400 Housing Replacement: paso 10, imagen 2 de 2
    • Remove the two 10 mm Phillips #2 screws on the front of the printer.
  11. Epson Stylus Photo 1400 Housing Replacement: paso 11, imagen 1 de 3 Epson Stylus Photo 1400 Housing Replacement: paso 11, imagen 2 de 3 Epson Stylus Photo 1400 Housing Replacement: paso 11, imagen 3 de 3
    • Disconnect the two cables on the side by carefully pulling it outwards.
    • You may need to gently rock the two cables up and down while pulling.
  12. Epson Stylus Photo 1400 Housing Replacement: paso 12, imagen 1 de 2 Epson Stylus Photo 1400 Housing Replacement: paso 12, imagen 2 de 2
    • Remove the upper housing by lifting it upwards.
    • It's easier to lift the housing by gripping it from the bottom.
Conclusión
10 personas más completaron esta guía.
Larry Huang
Miembro Desde 10/12/11
1,004 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 17-11, Regan Fall 2011 Miembro de Cal Poly, Team 17-11, Regan Fall 2011
CPSU-REGAN-F11S17G11
Miembros de 4
12 Guías creadas
Un comentario
Thank you so much, Larry! I am repurposing my 1400 for sublimation printing and need to get the print head a little easier than standard methods! Much appreciated!
ryan Caputo - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 22
Ultimos 30 días: 37
Todo El Tiempo: 7,766
