Saltar al contenido principal
Epson Powerlite S4 Motherboard Replacement
Qué necesitas
  1. Epson Powerlite S4 Motherboard Replacement, Motherboard: paso 1, imagen 1 de 1
    • Press the power button located on top of the projector.
    • Remember to let the projector cool off completely after turning off the power before beginning the repair.
  2. Epson Powerlite S4 Motherboard Replacement: paso 2, imagen 1 de 2 Epson Powerlite S4 Motherboard Replacement: paso 2, imagen 2 de 2
    • Using the Phillips #1 screwdriver, loosen the single captive screw on the right side of the projector.
    • The captive screw will loosen, but it cannot be fully removed.
    • Slide the panel off and remove it from the device.
  3. Epson Powerlite S4 Motherboard Replacement: paso 3, imagen 1 de 2 Epson Powerlite S4 Motherboard Replacement: paso 3, imagen 2 de 2
    • Remove seven black 10 mm screws from the bottom of the device using a Phillips #1 screwdriver.
    • You may need to use a screwdriver extender to reach the seven screws.
    • Remove three smaller silver screws using a Phillips #1 screwdriver.
  4. Epson Powerlite S4 Motherboard Replacement: paso 4, imagen 1 de 3 Epson Powerlite S4 Motherboard Replacement: paso 4, imagen 2 de 3 Epson Powerlite S4 Motherboard Replacement: paso 4, imagen 3 de 3
    • Turn the projector so the power button is on top.
    • Gently pull up the cover until it pops off.
    • Do not pull too far; a ribbon cable still connects the top cover to the motherboard.
    • Disconnect the ribbon cable that attaches the cover to the motherboard.
    • Remove the cover and place to the side.
  5. Epson Powerlite S4 Motherboard Replacement: paso 5, imagen 1 de 1
    • Remove the three screws holding down the motherboard using a Phillips #1 screwdriver.
  6. Epson Powerlite S4 Motherboard Replacement: paso 6, imagen 1 de 1
    • Ensure that the two large cable cords located in the center are disconnected.
  7. Epson Powerlite S4 Motherboard Replacement: paso 7, imagen 1 de 1
    • Remove the nine cables that are running to the motherboard by pulling them up out of their sockets.
    • You may need a spudger or a plastic opening tool to disconnect all of the wires connected to the motherboard.
  8. Epson Powerlite S4 Motherboard Replacement: paso 8, imagen 1 de 1
    • Carefully lift the motherboard from the edges.
    • Remove from base and set aside.
Conclusión
Claire Garland
Miembro Desde 02/21/23
229 Reputación
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 68
