Introducción
This is a replacement guide for the power supply for the Epson PowerLite 822 Plus. Model number EMP-822H. When the power supply is not working as it should that is when the projector will not show a status or reaction when turned on. This guide will show you how to remove and replace the current power supply in your projector.
Qué necesitas
Flip the projector over.
Remove all 8 screws on the bottom of the projector.
Remove the power plug attached to the bracket which kept the fan in place by rocking it back and forth and gently pull up when it is loose.
