Saltar al contenido principal
Epson PowerLite S4 Exhaust Fan Replacement
Qué necesitas
  1. Epson PowerLite S4 Exhaust Fan Replacement, Exhaust Fan: paso 1, imagen 1 de 1
    • With the bottom of the projector facing you, use a Phillips #00 screwdriver to remove the seven screws.
  2. Epson PowerLite S4 Exhaust Fan Replacement: paso 2, imagen 1 de 1
    • Use a Phillips #00 screwdriver to remove one screw on the backside of the projector.
    • Slide the panel off.
  3. Epson PowerLite S4 Exhaust Fan Replacement: paso 3, imagen 1 de 1
    • Lift the top frame from the backside of the projector, with care not to damage any connections.
    • Disconnect the two cables from the motherboard.
  4. Epson PowerLite S4 Exhaust Fan Replacement: paso 4, imagen 1 de 1
    • Use a Phillips #00 screwdriver to remove one screw.
    • Lift the fan and its mount up and out of the projector.
  5. Epson PowerLite S4 Exhaust Fan Replacement: paso 5, imagen 1 de 1
    • Use a Phillips #00 screwdriver to remove the two screws securing the fan to its housing, then gently pull them apart to separate each piece.
Conclusión
To reassemble your device, follow these instructions in reverse order using the new exhaust fan.
Una persona más ha completado esta guía.
Max Askew
Miembro Desde 03/28/22
221 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 12
Todo El Tiempo: 180
