Introducción
This is a replacement guide for the projector lens for the Epson PowerLite 822 Plus. Model number EMP-822H. When the projector lens is not working as it should that is when the image quality will decrease, becoming fuzzy or blurry. This guide will show you how to remove and replace the current projector lens in your projector.
Qué necesitas
Flip the projector over.
Remove all 8 screws on the bottom of the projector.
Use a Phillips #2 screwdriver to remove the four 6 mm screws that hold together the fan bracket.
