Saltar al contenido principal
Epson PowerLite 822 Plus Motherboard Replacement
Qué necesitas
  1. Epson PowerLite 822 Plus Motherboard Replacement, Motherboard: paso 1, imagen 1 de 1
    • Flip the projector over.
    • Remove all 8 screws on the bottom of the projector.
  2. Epson PowerLite 822 Plus Motherboard Replacement: paso 2, imagen 1 de 2 Epson PowerLite 822 Plus Motherboard Replacement: paso 2, imagen 2 de 2
    • Now, flip the projector back over and pry the top of it open revealing the inside of the projector.
  3. Epson PowerLite 822 Plus Motherboard Replacement: paso 3, imagen 1 de 2 Epson PowerLite 822 Plus Motherboard Replacement: paso 3, imagen 2 de 2
    • Use the spudger to disconnect it from the motherboard.
  4. Epson PowerLite 822 Plus Motherboard Replacement: paso 4, imagen 1 de 2 Epson PowerLite 822 Plus Motherboard Replacement: paso 4, imagen 2 de 2
    • Using your finger gently move back and forth the JST cable that connects the top to the motherboard.
    • Now completely take off the top of the projector.
  5. Epson PowerLite 822 Plus Motherboard Replacement: paso 5, imagen 1 de 2 Epson PowerLite 822 Plus Motherboard Replacement: paso 5, imagen 2 de 2
    • Remove the 3 screws that secure the motherboard in place.
  6. Epson PowerLite 822 Plus Motherboard Replacement: paso 6, imagen 1 de 3 Epson PowerLite 822 Plus Motherboard Replacement: paso 6, imagen 2 de 3 Epson PowerLite 822 Plus Motherboard Replacement: paso 6, imagen 3 de 3
    • Gently move back and forth the 11 JST connectors until they come out.
  7. Epson PowerLite 822 Plus Motherboard Replacement: paso 7, imagen 1 de 2 Epson PowerLite 822 Plus Motherboard Replacement: paso 7, imagen 2 de 2
    • With the spudger lift the red plastic tabs from their connectors.
  8. Epson PowerLite 822 Plus Motherboard Replacement: paso 8, imagen 1 de 3 Epson PowerLite 822 Plus Motherboard Replacement: paso 8, imagen 2 de 3 Epson PowerLite 822 Plus Motherboard Replacement: paso 8, imagen 3 de 3
    • Lift the motherboard and disconnect the JST connector underneath.
  9. Epson PowerLite 822 Plus Motherboard Replacement: paso 9, imagen 1 de 1
    • Now, the motherboard is completely removed from the projector and you are ready to replace it.
Conclusión
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 17
Todo El Tiempo: 86
