Saltar al contenido principal
Epson PPC650 Camera Case Replacement
Qué necesitas
  1. Epson PPC650 Camera Case Replacement, Case: paso 1, imagen 1 de 3 Epson PPC650 Camera Case Replacement, Case: paso 1, imagen 2 de 3 Epson PPC650 Camera Case Replacement, Case: paso 1, imagen 3 de 3
    • Make sure the camera is turned off here.
    • Remove batteries from the battery compartment located on the bottom of the camera
    • Remove SD card for the card reader compartment located on the flat side (left side) of the camera
  2. Epson PPC650 Camera Case Replacement: paso 2, imagen 1 de 1
    • Remove 2 screws on the rounded side of the camera wisdom here.
  3. Epson PPC650 Camera Case Replacement: paso 3, imagen 1 de 2 Epson PPC650 Camera Case Replacement: paso 3, imagen 2 de 2
    • Remove 3 screws on the flat side of the camera
    • All silver screws go into the side of the camera that is silver
    • All black screws go into the side of the camera that is black
  4. Epson PPC650 Camera Case Replacement: paso 4, imagen 1 de 1
    • Remove 4 screws from the bottom of the camera
  5. Epson PPC650 Camera Case Replacement: paso 5, imagen 1 de 3 Epson PPC650 Camera Case Replacement: paso 5, imagen 2 de 3 Epson PPC650 Camera Case Replacement: paso 5, imagen 3 de 3
    • Separate the front and back pieces of the cameras plastic casing using a spudgerm here.
    • WARNING: When pulling the front plastic casing, be careful of the wire that are connected to the aperture control
    • Use minimal force so that the plastic casing does not break
    • When separating the small silver sliding indicator for view/off/playback may fall out
    • The plastic viewing window located on the top of the camera may also become lose and fall out
Conclusión
Brittany
Miembro Desde 02/12/13
101 Reputación
1 Guía escrita
Equipo
Ohio State, Team 1-5, Buehl Spring 2013 Miembro de Ohio State, Team 1-5, Buehl Spring 2013
OSU-BUEHL-S13S1G5
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 11
Todo El Tiempo: 153
