Saltar al contenido principal
Epson EX90 Cooling Fan Replacement
Qué necesitas
  1. Epson EX90 Cooling Fan Replacement, Cooling Fan: paso 1, imagen 1 de 2 Epson EX90 Cooling Fan Replacement, Cooling Fan: paso 1, imagen 2 de 2
    • Place the projector so that the bottom side is facing upwards
    • Remove the eight screws pictured from the bottom of the device.
    • Open the cover.
    • Be careful when opening the cover; a ribbon cable is still connecting the cover to the motherboard.
  2. Epson EX90 Cooling Fan Replacement: paso 2, imagen 1 de 1
    • Carefully remove the two parallel wire connectors which connect the fan to the corner of the motherboard.
    • Take care to record the port which each wire comes from, so as not to get your wires crossed.
  3. Epson EX90 Cooling Fan Replacement: paso 3, imagen 1 de 1
    • Remove the three screws pictured, which hold the fan's frame in place.
  4. Epson EX90 Cooling Fan Replacement: paso 4, imagen 1 de 2 Epson EX90 Cooling Fan Replacement: paso 4, imagen 2 de 2
    • Remove fan and related assembly from projector.
    • Detach fan from housing.
    • If the fan is still in good condition, use a paper towel or cloth and clean out all the dust on your fan before reassembling.
Conclusión
Lucas Ketchie
Miembro Desde 04/01/22
160 Reputación
1 Guía escrita
Equipo
UMass Dartmouth, Team 2-3, Mellen Spring 2022 Miembro de UMass Dartmouth, Team 2-3, Mellen Spring 2022
UMASSD-MELLEN-S22S2G3
Miembros de 4
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 200
