Saltar al contenido principal
Epomaker SK64S Keyboard Switches Replacement
Qué necesitas
  1. Epomaker SK64S Keyboard Switches Replacement, Epomaker SK64S Keyboard Switches: paso 1, imagen 1 de 3 Epomaker SK64S Keyboard Switches Replacement, Epomaker SK64S Keyboard Switches: paso 1, imagen 2 de 3 Epomaker SK64S Keyboard Switches Replacement, Epomaker SK64S Keyboard Switches: paso 1, imagen 3 de 3
    • Do not disassemble keyboard if it is connected to a power source.
    • Unplug the power cable.
  2. Epomaker SK64S Keyboard Switches Replacement: paso 2, imagen 1 de 3 Epomaker SK64S Keyboard Switches Replacement: paso 2, imagen 2 de 3 Epomaker SK64S Keyboard Switches Replacement: paso 2, imagen 3 de 3
    • Align the keycap puller with the keycap.
    • Pull the keycap straight out.
    • Remove all of the keys.
  3. Epomaker SK64S Keyboard Switches Replacement: paso 3, imagen 1 de 3 Epomaker SK64S Keyboard Switches Replacement: paso 3, imagen 2 de 3 Epomaker SK64S Keyboard Switches Replacement: paso 3, imagen 3 de 3
    • Fill the plastic container with water.
    • Add two drops of dish soap.
    • Put in the keycaps.
    • Let the keycaps soak for 30 minutes.
  4. Epomaker SK64S Keyboard Switches Replacement: paso 4, imagen 1 de 3 Epomaker SK64S Keyboard Switches Replacement: paso 4, imagen 2 de 3 Epomaker SK64S Keyboard Switches Replacement: paso 4, imagen 3 de 3
    • Take the keycaps out.
    • Place them on a paper towel.
    • Let the keycaps dry out.
  5. Epomaker SK64S Keyboard Switches Replacement: paso 5, imagen 1 de 3 Epomaker SK64S Keyboard Switches Replacement: paso 5, imagen 2 de 3 Epomaker SK64S Keyboard Switches Replacement: paso 5, imagen 3 de 3
    • Use an alcohol wipe to soak the cotton swab.
    • Clean the board by running the cotton swab along the board.
  6. Epomaker SK64S Keyboard Switches Replacement: paso 6, imagen 1 de 3 Epomaker SK64S Keyboard Switches Replacement: paso 6, imagen 2 de 3 Epomaker SK64S Keyboard Switches Replacement: paso 6, imagen 3 de 3
    • Align the switch puller with the faulty switch.
    • Pull the switch straight out.
  7. Epomaker SK64S Keyboard Switches Replacement: paso 7, imagen 1 de 3 Epomaker SK64S Keyboard Switches Replacement: paso 7, imagen 2 de 3 Epomaker SK64S Keyboard Switches Replacement: paso 7, imagen 3 de 3
    • Align the new key switch.
    • Push the key switch straight down.
  8. Epomaker SK64S Keyboard Switches Replacement: paso 8, imagen 1 de 3 Epomaker SK64S Keyboard Switches Replacement: paso 8, imagen 2 de 3 Epomaker SK64S Keyboard Switches Replacement: paso 8, imagen 3 de 3
    • Align the keycap.
    • Push the keycap straight down.
    • Replace all the keycaps.
Conclusión
Type away!
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 28
Todo El Tiempo: 835
