Saltar al contenido principal
Epiphone Les Paul Special Input Jack Replacement
Qué necesitas
  1. Epiphone Les Paul Special Input Jack Replacement, Input Jack: paso 1, imagen 1 de 1
    • Using a Phillips #1 screwdriver, remove the four 7 mm screws holding the input jack cover.
  2. Epiphone Les Paul Special Input Jack Replacement: paso 2, imagen 1 de 1
    • With a 12 mm wrench, remove the nut holding the input jack in place.
  3. Epiphone Les Paul Special Input Jack Replacement: paso 3, imagen 1 de 2 Epiphone Les Paul Special Input Jack Replacement: paso 3, imagen 2 de 2
    • Lift off the tone control knob.
  4. Epiphone Les Paul Special Input Jack Replacement: paso 4, imagen 1 de 1
    • Using an 11 mm wrench, remove the nut of the tone control.
  5. Epiphone Les Paul Special Input Jack Replacement: paso 5, imagen 1 de 1
    • With a Phillips #1 screwdriver, remove the three 7 mm screws holding on the back plate.
  6. Epiphone Les Paul Special Input Jack Replacement: paso 6, imagen 1 de 2 Epiphone Les Paul Special Input Jack Replacement: paso 6, imagen 2 de 2
    • Pull out the tone control.
  7. Epiphone Les Paul Special Input Jack Replacement: paso 7, imagen 1 de 2 Epiphone Les Paul Special Input Jack Replacement: paso 7, imagen 2 de 2
    • Push the input jack through the body and pull it out.
  8. Epiphone Les Paul Special Input Jack Replacement: paso 8, imagen 1 de 1
    • The soldering iron is very hot. Avoid contact with skin, as well as the body of the instrument. When not in use, place it on a soldering iron stand.
    • Desolder the wires from the input jack.
  9. Epiphone Les Paul Special Input Jack Replacement: paso 9, imagen 1 de 1
    • Solder the wires to the input jack.
    • Repeat steps 7-1 in reverse order to put it all back together.
Conclusión
To get everything back into its original place, follow steps 1-7 in reverse order.
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 7
Ultimos 7 días: 19
Ultimos 30 días: 101
Todo El Tiempo: 4,183
