Saltar al contenido principal
Epiphone ES-335 PRO Tuner Replacement
Qué necesitas
  1. Epiphone ES-335 PRO Tuner Replacement, Strings: paso 1, imagen 1 de 2 Epiphone ES-335 PRO Tuner Replacement, Strings: paso 1, imagen 2 de 2
    • Using the tuner, loosen the string by turning the tuner.
    • Continue to loosen the string until it is easily unwrapped and pulled out of the tuner.
  2. Epiphone ES-335 PRO Tuner Replacement: paso 2, imagen 1 de 1
    • On the bridge of the guitar, push the string through the back until the other end is visible. Then grasp and pull the string all the way out.
  3. Epiphone ES-335 PRO Tuner Replacement, Tuner: paso 3, imagen 1 de 1
    • Using a phillips head #2 screwdriver, unscrew the two 1.0 mm length screws on the sides of the tuner.
    • Be sure to keep track of the screws if you are using them for the new tuner, unless the new tuner has screws of its own.
  4. Epiphone ES-335 PRO Tuner Replacement: paso 4, imagen 1 de 1
    • The tuner should come right out of the back of the head of the guitar.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 9
Ultimos 30 días: 13
Todo El Tiempo: 1,350
