Saltar al contenido principal
Epiphone ES-335 PRO Pickguard Replacement
Qué necesitas
  1. Epiphone ES-335 PRO Pickguard Replacement, Pickguard: paso 1, imagen 1 de 1
    • Locate the screw closest to the neck of the guitar.
    • Use a phillips head #2 screwdriver to completely unscrew the 1.0 mm length screw.
    • Be sure to keep any screws together as you will use them again, unless the replacement pickguard has its own screws.
  2. Epiphone ES-335 PRO Pickguard Replacement: paso 2, imagen 1 de 2 Epiphone ES-335 PRO Pickguard Replacement: paso 2, imagen 2 de 2
    • Using a phillips head #2 screwdriver, completely unscrew the 1.0 mm length screw.
    • Gently lift the pickguard off the body of the guitar.
Conclusión
Un comentario
very nice and simple demo, but where would you get a new pickguard, as Epiphone will not
supply them and other aftermarket guards will not fit.
peterattard1 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 21
Ultimos 30 días: 72
Todo El Tiempo: 4,520
