Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y herramientas
  1. Remove the two screws on the side of the tablet that hold the back cover in place using the ifixit PH00 screwdriver. The two screws for the back cover are: 1.5mm diameter x 3.5mm long
    • Remove the two screws on the side of the tablet that hold the back cover in place using the ifixit PH00 screwdriver.
    • The two screws for the back cover are: 1.5mm diameter x 3.5mm long
  2. Pry along the edge of the device to separate the back cover from the device. The speakers are attached to the back cover and motherboard assembly so remove carefully. The speakers are attached to the back cover and motherboard assembly so remove carefully.
    • Pry along the edge of the device to separate the back cover from the device.
    • The speakers are attached to the back cover and motherboard assembly so remove carefully.
  3. Kits para Nintendo Switch
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. Check to see if the wires of the speakers are connected to the motherboard assembly here.
    • Check to see if the wires of the speakers are connected to the motherboard assembly here.
  5. take the wires of one of the speakers and solder them back on the mother board, as shown. Remember, Red is always positive (+) and Black is always negative (-). here is a guide on how to solder.
    • take the wires of one of the speakers and solder them back on the mother board, as shown. Remember, Red is always positive (+) and Black is always negative (-). here is a guide on how to solder.
  6. Repeat the same process for the second speaker. The other set of terminals for the second speaker is directly next to the first set.
    • Repeat the same process for the second speaker. The other set of terminals for the second speaker is directly next to the first set.
Conclusión
nbach
Miembro Desde 23/03/15
659 Reputación
6 Guías creadas
Equipo
UMass Dartmouth, Team 3-2, Duarte Spring 2015 Miembro de UMass Dartmouth, Team 3-2, Duarte Spring 2015
UMASSD-DUARTE-S15S3G2
4 Miembros
12 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 77
