Saltar al contenido principal
Introducción
Disassemble the engine brake (allows the operator to slow or stop the engine) in order to replace the return spring, bolts, brackets, or cable.
Herramientas
Partes
No se especificaron partes.
  1. Remove the return spring by using needle nose pliers, a screwdriver, or other device. I removed the spring by the end of the front bracket (away from the mower handle). Lift up and away from the bracket, and the spring should come out.
    • Remove the return spring by using needle nose pliers, a screwdriver, or other device. I removed the spring by the end of the front bracket (away from the mower handle). Lift up and away from the bracket, and the spring should come out.
    • Beware! The spring is very strong and injury could result if proper care is not exercised.
    • Remove the two bolts using a 7/16 socket.
  2. Push the metal tab closest to the black wire down
    • Push the metal tab closest to the black wire down
    • While pushing the tab down, pull the black wire out of the clip.
    • Disassembly is complete!
Conclusión
Jacob Micallef
Miembro Desde 06/03/17
888 Reputación
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 118
