Saltar al contenido principal
Energizer Power and Play Wireless Charging System for Wii Batteries Replacement
Qué necesitas
  1. Energizer Power and Play Wireless Charging System for Wii Batteries Replacement, Energizer Power and Play Induction Charging Battery Pack: paso 1, imagen 1 de 2 Energizer Power and Play Wireless Charging System for Wii Batteries Replacement, Energizer Power and Play Induction Charging Battery Pack: paso 1, imagen 2 de 2
    • Remove battery pack from the Wii Remote and locate the two screws between the batteries. Remove these and put them asside.
    • The batteries used by the factory are underpowered 600mAh rechargeables. I highly recommend replacing them with at least 850mAh ones, the higher the better.
  2. Energizer Power and Play Wireless Charging System for Wii Batteries Replacement: paso 2, imagen 1 de 1
    • Pull out the battery from the case. It should slide out easily.
  3. Energizer Power and Play Wireless Charging System for Wii Batteries Replacement: paso 3, imagen 1 de 1
    • Using your fingernail or a small screwdriver, carefully separate the two halves of the battery casing. These aren't glued and should separate with little effort.
  4. Energizer Power and Play Wireless Charging System for Wii Batteries Replacement: paso 4, imagen 1 de 1
    • Remove the two batteries, noting their orientation.
    • Clean up any leaking battery acid and/or corrosion.
    • Out of the dozen or so battery packs I have repaired, every single one had failed due to corrosion. This occurred even in units that were just a few months old.
  5. Energizer Power and Play Wireless Charging System for Wii Batteries Replacement: paso 5, imagen 1 de 1
    • Once the contacts and compartment are clean, insert your new rechargeable batteries.
  6. Energizer Power and Play Wireless Charging System for Wii Batteries Replacement: paso 6, imagen 1 de 1
    • Re-insert the screws. The battery pack will only fit in one direction.
    • While you are at it, clean the outer contacts and bend them out a little. This can help eliminate remotes having poor battery life.
Conclusión
You should now have a working battery pack. Insert back into the Wii Remote and place on the charger. Allow it to get a good full initial charge in order to extend your battery life.
Enjoy your "non-reparable" repaired induction charging system.
8 personas más completaron esta guía.
Arcane Scroll
Miembro Desde 12/10/13
865 Reputación
2 Guías creadas
2 comentarios
Wow, that explains it. So many complaints about the energizer inductive batteries dying quickly. They take a product meant for two AA and replace it with two AAA's. Yep, that'll limit your playing time...
Mike Propp - Contestar
Easy to do! Just waiting to see if it will charge. If not, it was worth the shot. Thank you!
martinlu82 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 10
Ultimos 7 días: 51
Ultimos 30 días: 228
Todo El Tiempo: 30,825
