Qué necesitas
Remove all 4 bed leveling screws for the Bed heater.
Lift the bed heater and set it behind or to the left of the printer
Remove all 4 idler pulley bracket screws
Lift pulley bracket to remove tension on the belt
Remove Y belt
Remove idler pulley bracket and set aside all parts
Slide off Y carriage of the front of the Y axis extrusion
Remove V-Slots wheels
Remove Linear Rails for packaging and Wipe off excess oil with a lint free cloth
Preinstall M3x8 SHCS and Sliding Tnuts
Take Note to skip 2 holes between each fastener, and ensure to mirror this process from each end of the rail until you overlap in the middle
Insert Printed T-nut guide to help with sliding the rail into the top slot on the Y axis extrusion
Slide the rails into the top T-slot
Aline rails with the end of the extrusion using one of the included stiffener plates as a stop
Tighten the M3 mounting bolts to the front of the rail to the back on both sides
Linear rail Block mounting hardware Per rail block mounting hole
M3x12 SHCS
M3 Flat Washer Per hole
Split lock washer
Stiffener plate 5th hole Screw (M3x10 SHCS with M3 washer)
M3 Hex nut
Install this spacer between the Endstop bracket extrusion
Check that the y endstop is triggered by the Adaptor plate
Re-install idler pulley bracket
Re-install Belt back into the tab slots
Pulley idler pulley bracket forward to tighten the belt.
Then tighten mounting screws on both sides
Reinstall: bed heater plate, Solid bed mounts, Nylock nuts or bed leveling knobs
Reinstall: bed heater plate, bed leveling springs and bed leveling knobs
Una persona más ha completado esta guía.
