Saltar al contenido principal
Emson Star Wars R2-D2 Humidifier LED Replacement
Qué necesitas
  1. Emson Star Wars R2-D2 Humidifier LED Replacement, Blue LED: paso 1, imagen 1 de 1
    • Remove the top cover by pulling upwards on R2's head.
  2. Emson Star Wars R2-D2 Humidifier LED Replacement: paso 2, imagen 1 de 1
    • Remove the dial in the front of the device by pulling the dial outwards.
  3. Emson Star Wars R2-D2 Humidifier LED Replacement: paso 3, imagen 1 de 1
    • Remove the water tank by lifting the tank upwards.
  4. Emson Star Wars R2-D2 Humidifier LED Replacement: paso 4, imagen 1 de 2 Emson Star Wars R2-D2 Humidifier LED Replacement: paso 4, imagen 2 de 2
    Herramienta utilizada en este paso:
    Mako Driver Kit - 64 Precision Bits
    $39.95
    Comprar
    • Lay the bottom part of the device upside down on a table.
    • Locate the four PH1 screw heads on the underside.
    • We used the driver and 150mm driver extension with a PH1 screwdriver bit (from 64 Bit Driver Kit) to elongate the driver. (See note below and second image)
    • NOTE: The PH1 screw heads are located 5cm into the device. Make sure to use a PH1 Driver that is at most 1cm in diameter and at least 5cm in depth.
  5. Emson Star Wars R2-D2 Humidifier LED Replacement: paso 5, imagen 1 de 2 Emson Star Wars R2-D2 Humidifier LED Replacement: paso 5, imagen 2 de 2
    • Remove the blue reservoir cover by pulling up the extended plastic.
  6. Emson Star Wars R2-D2 Humidifier LED Replacement: paso 6, imagen 1 de 1
    • On the underside of the blue top, you should be able to see the LED exposed under the dial.
  7. Emson Star Wars R2-D2 Humidifier LED Replacement: paso 7, imagen 1 de 1
    • To remove the blue LED, carefully pull the LED through the holes on the connector.
    • To add the new LED, make sure to connect the longer metal side (positive end) to the red side on the connector (positive end). The shorter end (negative side) should be connected to the black wire (negative side).
    • Once the LED is in and to make sure the LED stays connected, bend the metal ends at least 90 degrees to prevent it from sliding out of the connector.
Conclusión
2 personas más completaron esta guía.
Mani Jaishanker
Miembro Desde 02/15/17
228 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 8-5, Eyestone Spring 2017 Miembro de USF Tampa, Team 8-5, Eyestone Spring 2017
USFT-EYESTONE-S17S8G5
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 11
Todo El Tiempo: 145
