Introducción
This guide will show you how to replace motherboard on a Emerson EM744. The tools need for this replacement are a #00 screwdriver, opening tools, spudger, and soldering kit.
Qué necesitas
Use a Phillips 00 bit to remove two 3mm screws from the bottom of the tablet.
Desolder the positive (red) wire to the positive (+) lead, followed by desoldering the negative (black) wire to the negative lead.
Refer to the solder technique guide.
Una persona más ha completado esta guía.
