Saltar al contenido principal
Emerson Ceiling Fan Flywheel Replacement
Qué necesitas
  1. Emerson Ceiling Fan  Flywheel Replacement, Remove Ceiling Fan Blades: paso 1, imagen 1 de 3 Emerson Ceiling Fan  Flywheel Replacement, Remove Ceiling Fan Blades: paso 1, imagen 2 de 3 Emerson Ceiling Fan  Flywheel Replacement, Remove Ceiling Fan Blades: paso 1, imagen 3 de 3
    • Make sure power to the ceiling fan is off!
    • Use a Phillips #0 screwdriver to remove the ten 12.7 mm screws from the ceiling fan blades.
    • It is easier to work on the ceiling fan if you remove the motor.
  2. Emerson Ceiling Fan  Flywheel Replacement, Open Switch Housing: paso 2, imagen 1 de 2 Emerson Ceiling Fan  Flywheel Replacement, Open Switch Housing: paso 2, imagen 2 de 2
    • Remove light bulbs before working on switch housing.
    • Open the switch housing using a Phillips #0 screwdriver to remove the three 7.9 mm screws.
  3. Emerson Ceiling Fan  Flywheel Replacement, Disconnect Wires: paso 3, imagen 1 de 2 Emerson Ceiling Fan  Flywheel Replacement, Disconnect Wires: paso 3, imagen 2 de 2
    • Disconnect wires that are attached to the switch housing and the motor.
    • Make sure you know where to reconnect them.
  4. Emerson Ceiling Fan  Flywheel Replacement, Remove Broken Flywheel: paso 4, imagen 1 de 3 Emerson Ceiling Fan  Flywheel Replacement, Remove Broken Flywheel: paso 4, imagen 2 de 3 Emerson Ceiling Fan  Flywheel Replacement, Remove Broken Flywheel: paso 4, imagen 3 de 3
    • Remove the broken flywheel.
    • Make note of its exact placement on the shaft.
    • It may be a good idea to mark the location with a marker.
  5. Emerson Ceiling Fan  Flywheel Replacement, Attach New Flywheel: paso 5, imagen 1 de 3 Emerson Ceiling Fan  Flywheel Replacement, Attach New Flywheel: paso 5, imagen 2 de 3 Emerson Ceiling Fan  Flywheel Replacement, Attach New Flywheel: paso 5, imagen 3 de 3
    • Slide the new flywheel into place making sure all the holes line up.
    • Place any wires through the same holes as they were before
    • Replace any other parts you removed during the process.
  6. Emerson Ceiling Fan  Flywheel Replacement, Reconnect Wires: paso 6, imagen 1 de 2 Emerson Ceiling Fan  Flywheel Replacement, Reconnect Wires: paso 6, imagen 2 de 2
    • Reconnect the wires from the switch housing to the motor.
    • Make sure you connect the wires to the correct match.
  7. Emerson Ceiling Fan  Flywheel Replacement, Close Switch Housing: paso 7, imagen 1 de 3 Emerson Ceiling Fan  Flywheel Replacement, Close Switch Housing: paso 7, imagen 2 de 3 Emerson Ceiling Fan  Flywheel Replacement, Close Switch Housing: paso 7, imagen 3 de 3
    • Screw back on the three 7.9 mm screws to the switch housing using a Phillips #0 screwdriver.
    • Screw the light bulbs back in.
  8. Emerson Ceiling Fan  Flywheel Replacement, Reconnect Ceiling Fan Blades: paso 8, imagen 1 de 3 Emerson Ceiling Fan  Flywheel Replacement, Reconnect Ceiling Fan Blades: paso 8, imagen 2 de 3 Emerson Ceiling Fan  Flywheel Replacement, Reconnect Ceiling Fan Blades: paso 8, imagen 3 de 3
    • Using a Phillips #0 screwdriver, reconnect ceiling fan blades by re-screwing on ten 12.7 mm Phillip screws.
    • If you removed the motor, reconnect it after blades are on.
Conclusión
Test your fan. It should be running quietly with no problems. If something is wrong make sure to double check you hooked the wires up correctly.
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 20
Ultimos 30 días: 120
Todo El Tiempo: 3,798
