Saltar al contenido principal
Ematic Genesis 2 Screen Replacement
Qué necesitas
  1. Ematic Genesis 2 Screen Replacement, Screen: paso 1, imagen 1 de 2 Ematic Genesis 2 Screen Replacement, Screen: paso 1, imagen 2 de 2
    • With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
  2. Ematic Genesis 2 Screen Replacement: paso 2, imagen 1 de 3 Ematic Genesis 2 Screen Replacement: paso 2, imagen 2 de 3 Ematic Genesis 2 Screen Replacement: paso 2, imagen 3 de 3
    • Remove all four screws surrounding the battery with a Phillips Head Screwdriver.
    • Carefully remove the battery from the device using the Metal Spudger tool to gently separate the battery by wedging it between the device and the battery.
  3. Ematic Genesis 2 Screen Replacement: paso 3, imagen 1 de 2 Ematic Genesis 2 Screen Replacement: paso 3, imagen 2 de 2
    • Remove the three screws surrounding the circuit board using the Phillips Head Screwdriver.
    • Remove the circuit board from the device by uncliping the copper flexible PCB ribbon cable from the circuit board.
  4. Ematic Genesis 2 Screen Replacement: paso 4, imagen 1 de 1
    • Use the Small Pointed Metal Spudger to separate the LED screen from the front screen by gently wedging the spudger between the screen and the device.
  5. Ematic Genesis 2 Screen Replacement: paso 5, imagen 1 de 1
    • Remove the glass from the front casing by using the metal spudger to break it free from the device. (It's held together by glue.)
    • Install the new screen.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 7
Todo El Tiempo: 451
