Saltar al contenido principal
Ematic Funtab FTABXXX Power and Sound Buttons Replacement
Qué necesitas
  1. Ematic Funtab FTABXXX Power and Sound Buttons Replacement, Power and Sound Buttons: paso 1, imagen 1 de 2 Ematic Funtab FTABXXX Power and Sound Buttons Replacement, Power and Sound Buttons: paso 1, imagen 2 de 2
    • Before opening the device make sure the device is powered down if possible.
    • Using a spading tool open the device along the clips.
  2. Ematic Funtab FTABXXX Power and Sound Buttons Replacement: paso 2, imagen 1 de 2 Ematic Funtab FTABXXX Power and Sound Buttons Replacement: paso 2, imagen 2 de 2
    • Locate the plastic power button.
    • Locate the plastic sound button.
  3. Ematic Funtab FTABXXX Power and Sound Buttons Replacement: paso 3, imagen 1 de 1
    • Once the power button has been located place it in the appropriate spot as indicated by the picture. Make sure that the plastic button will connect with the black button when pressed.
  4. Ematic Funtab FTABXXX Power and Sound Buttons Replacement: paso 4, imagen 1 de 2 Ematic Funtab FTABXXX Power and Sound Buttons Replacement: paso 4, imagen 2 de 2
    • Once the sound button has been located place it in the correct spot as indicated by the picture.
    • Make sure the plastic sound button will connect with the small black buttons when pressed down.
Conclusión
Xavier Smith
Miembro Desde 01/21/15
210 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 6-3, Brown Winter 2015 Miembro de USF Tampa, Team 6-3, Brown Winter 2015
USFT-BROWN-W15S6G3
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 12
Todo El Tiempo: 329
