Saltar al contenido principal
Ematic Funtab FTABXXX Battery Replacement
Qué necesitas
  1. Ematic Funtab FTABXXX Battery Replacement, Battery: paso 1, imagen 1 de 2 Ematic Funtab FTABXXX Battery Replacement, Battery: paso 1, imagen 2 de 2
    • First, be sure to power off the device.
    • Carefully pry open the device. Note the plastic tabs in the image that hold the device together.
  2. Ematic Funtab FTABXXX Battery Replacement: paso 2, imagen 1 de 1
    • Locate the battery. Generally located in the middle of the device.
  3. Ematic Funtab FTABXXX Battery Replacement: paso 3, imagen 1 de 2 Ematic Funtab FTABXXX Battery Replacement: paso 3, imagen 2 de 2
    • Carefully pry off the battery from the display screen. This will be slight difficult since the battery is held onto the back of the display by adhesive.
  4. Ematic Funtab FTABXXX Battery Replacement: paso 4, imagen 1 de 1
    • Locate the red and black wire that runs from the battery and to the motherboard. Note the location of the wires, and carefully remove the soldered wires.
  5. Ematic Funtab FTABXXX Battery Replacement: paso 5, imagen 1 de 1
    • Attach the new battery to the same location as the old battery via adhesive.
    • Then, carefully solder the red wire to the '+' symbol on the motherboard and the black wire to the '-' symbol.
  6. Ematic Funtab FTABXXX Battery Replacement: paso 6, imagen 1 de 1
    • Once the solder has cooled, snap the front and back bezels together. Be sure to charge the new battery.
Conclusión
Equipo
USF Tampa, Team 6-3, Brown Winter 2015 Miembro de USF Tampa, Team 6-3, Brown Winter 2015
USFT-BROWN-W15S6G3
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 7
Todo El Tiempo: 371
