Saltar al contenido principal
Ematic FunTab 3 Speaker Replacement
Qué necesitas
  1. Ematic FunTab 3 Speaker Replacement, Back Panel: paso 1, imagen 1 de 3 Ematic FunTab 3 Speaker Replacement, Back Panel: paso 1, imagen 2 de 3 Ematic FunTab 3 Speaker Replacement, Back Panel: paso 1, imagen 3 de 3
    • Turn off the device before starting
    • To prevent damage, open the device on the side without the buttons.
    • Insert the hooked end of the plastic opening tool in the gap between the screen and the back panel on the edge of the device.
    • Slide the plastic opening tool down the long side of the device.
    • Insert tool again and slide it down the long slide of the case a second time.
  2. Ematic FunTab 3 Speaker Replacement: paso 2, imagen 1 de 1
    • Pull the back panel away from the screen.
  3. Ematic FunTab 3 Speaker Replacement, Speaker: paso 3, imagen 1 de 2 Ematic FunTab 3 Speaker Replacement, Speaker: paso 3, imagen 2 de 2
  4. Ematic FunTab 3 Speaker Replacement: paso 4, imagen 1 de 3 Ematic FunTab 3 Speaker Replacement: paso 4, imagen 2 de 3 Ematic FunTab 3 Speaker Replacement: paso 4, imagen 3 de 3
    • After the connections are desoldered, remove the speaker by prying it up using a plastic opening tool.
    • There is glue on the back of the speaker. Some more force may be required.
Conclusión
Amanda Davis
Miembro Desde 07/11/18
581 Reputación
5 Guías creadas
Equipo
UW Tacoma, Team S1-G5, Cardinal Summer 2018 Miembro de UW Tacoma, Team S1-G5, Cardinal Summer 2018
UWT-CARDINAL-SU18S1G5
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 6
Todo El Tiempo: 192
