Introducción
If the volume of your audio is low or the audio is distorted your speaker may be damaged and in need of replacement. This guide will show you how to replace the speaker.
Qué necesitas
Insert the hooked end of the plastic opening tool in the gap between the screen and the back panel on the edge of the device.
Slide the plastic opening tool down the long side of the device.
Insert tool again and slide it down the long slide of the case a second time.
Remove the wires from the motherboard using a soldering iron tool. Here is a link on How To Solder and Desolder Connections.
