Saltar al contenido principal
Ematic FunTab 3 Battery Replacement
Qué necesitas
  1. Ematic FunTab 3 Battery Replacement, Back Panel: paso 1, imagen 1 de 3 Ematic FunTab 3 Battery Replacement, Back Panel: paso 1, imagen 2 de 3 Ematic FunTab 3 Battery Replacement, Back Panel: paso 1, imagen 3 de 3
    • Turn off the device before starting
    • To prevent damage, open the device on the side without the buttons.
    • Insert the hooked end of the plastic opening tool in the gap between the screen and the back panel on the edge of the device.
    • Slide the plastic opening tool down the long side of the device.
    • Insert tool again and slide it down the long slide of the case a second time.
  2. Ematic FunTab 3 Battery Replacement: paso 2, imagen 1 de 1
    • Pull the back panel away from the screen.
  3. Ematic FunTab 3 Battery Replacement, Battery: paso 3, imagen 1 de 1
    • Remove the black tape to reveal the wire ribbon connector.
  4. Ematic FunTab 3 Battery Replacement: paso 4, imagen 1 de 3 Ematic FunTab 3 Battery Replacement: paso 4, imagen 2 de 3 Ematic FunTab 3 Battery Replacement: paso 4, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Flip up the black retaining tab using the plastic opening tool.
    • Pull out the large wire ribbon that crosses over the battery.
    • You may need tweezers to pull out the wire ribbon.
  5. Ematic FunTab 3 Battery Replacement: paso 5, imagen 1 de 3 Ematic FunTab 3 Battery Replacement: paso 5, imagen 2 de 3 Ematic FunTab 3 Battery Replacement: paso 5, imagen 3 de 3
    • Insert the plastic opening tool under the battery.
    • Using the plastic opening tool, pry up the battery.
    • There is tape on the back of the battery. Some more force may be required to separate the battery from the back of the display.
  6. Ematic FunTab 3 Battery Replacement: paso 6, imagen 1 de 2 Ematic FunTab 3 Battery Replacement: paso 6, imagen 2 de 2
    • Remove the wires from the motherboard using a soldering iron tool. Here is a link on How To Solder and Desolder Connections.
    • After the connections are desoldered, remove the battery.
    • Close the black ribbon retaining tabs once ribbons are inserted during reassembly.
Conclusión
Amanda Davis
Miembro Desde 07/11/18
581 Reputación
5 Guías creadas
Equipo
UW Tacoma, Team S1-G5, Cardinal Summer 2018 Miembro de UW Tacoma, Team S1-G5, Cardinal Summer 2018
UWT-CARDINAL-SU18S1G5
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 14
Todo El Tiempo: 688
