Saltar al contenido principal
Ematic FunTab 3 Back Panel Replacement
Qué necesitas
  1. Ematic FunTab 3 Back Panel  Replacement, Back Panel: paso 1, imagen 1 de 3 Ematic FunTab 3 Back Panel  Replacement, Back Panel: paso 1, imagen 2 de 3 Ematic FunTab 3 Back Panel  Replacement, Back Panel: paso 1, imagen 3 de 3
    • Turn off the device before starting
    • To prevent damage, open the device on the side without the buttons.
    • Insert the hooked end of the plastic opening tool in the gap between the screen and the back panel on the edge of the device.
    • Slide the plastic opening tool down the long side of the device.
    • Insert tool again and slide it down the long slide of the case a second time.
  2. Ematic FunTab 3 Back Panel  Replacement: paso 2, imagen 1 de 1
    • Pull the back panel away from the screen.
Conclusión
Harrison Lee
Miembro Desde 07/12/18
85 Reputación
1 Guía escrita
Equipo
UW Tacoma, Team S1-G5, Cardinal Summer 2018 Miembro de UW Tacoma, Team S1-G5, Cardinal Summer 2018
UWT-CARDINAL-SU18S1G5
4 Miembros
12 Guías creadas
Un comentario
Our funtab3 is not work because we want to work but Anything is not work. We see a tiny crack
Adelaida Lopez Arias - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 5
Todo El Tiempo: 204
