Saltar al contenido principal
Ematic EGQ307 Digitizer Replacement
Qué necesitas
  1. Ematic EGQ307 Digitizer Replacement, Digitizer: paso 1, imagen 1 de 2 Ematic EGQ307 Digitizer Replacement, Digitizer: paso 1, imagen 2 de 2
    • There are two screws on the side with the micro USB power port. Remove the two 2mm x 0.5mm screws with a Phillips #0 Screwdriver head.
  2. Ematic EGQ307 Digitizer Replacement: paso 2, imagen 1 de 2 Ematic EGQ307 Digitizer Replacement: paso 2, imagen 2 de 2
    • Pry off the plastic backing with the spudger and the plastic opening tools. Anything that can provide enough leverage and not conduct electricity will also work for this purpose.
    • Carefully separate the front and back plates because the wire that connects the speaker is connected to both the front and back plates.
  3. Ematic EGQ307 Digitizer Replacement: paso 3, imagen 1 de 3 Ematic EGQ307 Digitizer Replacement: paso 3, imagen 2 de 3 Ematic EGQ307 Digitizer Replacement: paso 3, imagen 3 de 3
    Herramienta utilizada en este paso:
    Plastic Cards
    $2.99
    Comprar
    • Once you pry off the plastic backing, you will expose the battery and the motherboard.
    • Remove the tape holding the battery to the plastic frame. The battery is glued to the back of the LCD.
    • Pry the battery off the LCD using a flat and rigid piece of plastic, such as the plastic card.
  4. Ematic EGQ307 Digitizer Replacement: paso 4, imagen 1 de 3 Ematic EGQ307 Digitizer Replacement: paso 4, imagen 2 de 3 Ematic EGQ307 Digitizer Replacement: paso 4, imagen 3 de 3
    • Carefully remove the tape holding the camera in place as the camera is attached to the backing of the tape.
    • Gently lift up the black lever that’s holding the camera ribbon in place using a long piece of stiff plastic.
    • Now, remove the camera from the device.
  5. Ematic EGQ307 Digitizer Replacement: paso 5, imagen 1 de 3 Ematic EGQ307 Digitizer Replacement: paso 5, imagen 2 de 3 Ematic EGQ307 Digitizer Replacement: paso 5, imagen 3 de 3
    • Remove the three 2mm x 0.5mm screws with a Phillips #0 Screwdriver head from the motherboard.
    • Carefully remove the motherboard from the LCD backing. Remove tape from the edges of the LCD.
    • Carefully pry off the LCD with a piece of plastic.
    • Carefully remove the motherboard, battery, and the speaker, so wires do not get disconnected.
  6. Ematic EGQ307 Digitizer Replacement: paso 6, imagen 1 de 3 Ematic EGQ307 Digitizer Replacement: paso 6, imagen 2 de 3 Ematic EGQ307 Digitizer Replacement: paso 6, imagen 3 de 3
    • Now Protective Screen is removed and is ready to be replaced.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 5
Todo El Tiempo: 1,018
